  1. Hi, I'm here again with a new sync issue, which I can't solve, pls help.
    The purpose is to use the PAL DVD audio on a 24000/1001 BD video source.
    But something is weird with the DVD, it has 6 interlaced frames plus maybe 19 normal frames.
    I just have to fix the DVD frames in order to match with the BD.
    but how?
    using TFM(), fixes the interlaced frames but produces a doubled frame every 24 or 25 frames.
    so i think maybe I have to add another command. which one?
    TFM().TDecimate() is not working good, some frames are missing.-
    help pls-
    10 min sample:
    https://www.dropbox.com/s/7a7psgsywjeesyp/A1_t00.mkv%20-%20sample.mkv?dl=0
    DVD mediainfo:
    it says
    Frame rate : 24.000 FPS
    Original frame rate : 25.000 FPS
    General
    Unique ID                   : 302356912509984112593159902664864897774 (0xE377D2BB3D42DACBC515CF20A68D1AEE)
    Complete name               : C:\Users\antip\Desktop\Freeway - No Exit (Bright, 1996)\makemkv\A1_t00.mkv
    Format                      : Matroska
    Format version              : Version 2
    File size                   : 3.46 GiB
    Duration                    : 1 h 41 min
    Overall bit rate mode       : Variable
    Overall bit rate            : 4 853 kb/s
    Encoded date                : UTC 2022-12-19 13:30:01
    Writing application         : MakeMKV v1.17.1 win(x64-release)
    Writing library             : libmakemkv v1.17.1 (1.3.10/1.5.2) win(x64-release)
    Video
    ID in the original source m : 224 (0xE0)
    Format                      : MPEG Video
    Format profile              : Main@Main
    Format settings             : BVOP
    Format settings, BVOP       : Yes
    Format settings, Matrix     : Default
    Format settings, GOP        : M=3, N=12
    Codec ID                    : V_MPEG2
    Codec ID/Info               : MPEG 1 or 2 Video
    Bit rate mode               : Variable
    Bit rate                    : 4 201 kb/s
    Maximum bit rate            : 9 200 kb/s
    Width                       : 720 pixels
    Height                      : 576 pixels
    Display aspect ratio        : 16:9
    Frame rate mode             : Variable
    Standard                    : Component
    Color space                 : YUV
    Chroma subsampling          : 4:2:0
    Bit depth                   : 8 bits
    Scan type                   : Progressive
    Compression mode            : Lossy
    Bits/(Pixel*Frame)          : 0.422
    Time code of first frame    : 00:00:00:00
    Time code source            : Group of pictures header
    GOP, Open/Closed            : Closed
    Stream size                 : 2.99 GiB (87%)
    Language                    : English
    Default                     : No
    Forced                      : No
    Color primaries             : BT.601 PAL
    Transfer characteristics    : BT.470 System B/G
    Matrix coefficients         : BT.470 System B/G
    Original source medium      : DVD-Video
    Audio #1
    ID in the original source m : 189 (0xBD)128 (0x80)
    Format                      : AC-3
    Format/Info                 : Audio Coding 3
    Commercial name             : Dolby Digital
    Codec ID                    : A_AC3
    Bit rate mode               : Constant
    Bit rate                    : 448 kb/s
    Channel(s)                  : 6 channels
    Channel layout              : L R C LFE Ls Rs
    Sampling rate               : 48.0 kHz
    Frame rate                  : 31.250 FPS (1536 SPF)
    Stream size                 : 327 MiB (9%)
    Title                       : Surround 5.1
    Language                    : English
    Service kind                : Complete Main
    Default                     : Yes
    Forced                      : No
    Audio #2
    ID in the original source m : 189 (0xBD)129 (0x81)
    Format                      : AC-3
    Codec ID                    : A_AC3
    Bit rate                    : 192 kb/s
    Channel(s)                  : 2 channels
    Stream size                 : 140 MiB (4%)
    Title                       : Stereo
    Language                    : Italian
    Default                     : No
    Forced                      : No
    Text
    ID in the original source m : 189 (0xBD)32 (0x20)
    Format                      : VobSub
    Codec ID                    : S_VOBSUB
    Codec ID/Info               : Picture based subtitle format used on DVDs
    Duration                    : 1 h 37 min
    Bit rate                    : 6 221 b/s
    Frame rate                  : 0.286 FPS
    Count of elements           : 1666
    Stream size                 : 4.32 MiB (0%)
    Language                    : English
    Default                     : Yes
    Forced                      : No
    Menu
    00:00:00.000                : en:Chapter 01
    00:04:22.480                : en:Chapter 02
    00:10:24.480                : en:Chapter 03
    00:22:08.000                : en:Chapter 04
    00:38:19.000                : en:Chapter 05
    00:59:55.000                : en:Chapter 06
    01:26:33.000                : en:Chapter 07
    01:38:32.480                : en:Chapter 08
  2. TDecimate(Cycle=25, CycleR=1) ?
  3. yes, thx it works.
